1 - 12 of 12 Posts
i know this is dumb question, but...
back in my BMX days we used to use a small amount of dish soap to put new handgrips on handlebars. the rubber grips eventually took some muscling once you got to a certain point, but made us strong kids and racers. the soap would dry sticky and work as a glue. at least i think i remember doing this? well here i am 20 some years later trying to do something similar. i bought a new kick-start rubber piece the other day and am wondering what you guys would recommend for an easy and long-lasting installation. lube or brut force or ?
dumb question addendum: is the rubber, once installed, supposed to spin freely if it wants to or should it really be GLUED in place. many thanks in advance.
-seth
I used force with twisting to put it on. Eventually it slipped on. It still "moves" around after giving it a couple kicks, but it doesn't twirl around as if it is free.
just lube it with soap any glue you put on will be pushed out by the knob on the end of the shaft, warm it up with a heat gun or hair dryer, makes the rubber pliable, will go on a lot easier
Kick start rubbers are the toughest ones to do, by far.
I usually soak them in Xylol for an hour or so first - they'll swell up and be much easier to get on.
In a few days they'll go back to normal size......
Discussion Starter #5
awesome, thanks. surprised i got this many different ideas to try. i don't have a hair dryer or heat gun so i was thinking of boiling the thing and then going the soap route. i'll let you know how i make out.
Boiling would probably work too......
Here is another one I use. Spray some brake cleaner on the rubber and it'll slide right on. The cleaner evaporates quickly and in a few minutes it should be firm. The kick start levers have a little lip on them so have them slide off is not usually a big problem.
I like to apply rubber grease to the stem then dunk the rubber into a mug of hot boiled water for a few seconds before pressing it on.
OR, you can try something new. I always HATED changing grips on my bikes, and it's a frequent thing with motocross and off-road riding. We always had grip glue, and it worked well, but it still made for sore hands and arms after getting them in place. However, we've got a new product in the store, and I am in LOVE with it.
When you put this new grip glue on, it's got the consistency of mineral oil. Extremely slippery, and the grips slide right on. However, you've got 10-25 seconds of working time where it slides like this, and then it turns into a form that I swear is stronger than any super glue. As with all these products I was very hesitant to use it at first, but I finally took a bottle home, took a deep breath...and had both my grips changed in 2 minutes flat with no problems at all. Even better? Read on...
Standard grip glue works ok, but we still would wire braid the ends to keep them from rolling. I absolutely can NOT get these grips to turn, just using this stuff. It's the best I've ever seen, and I swear by it. You should be able to find it online, at any motorcycle dealer, or I'll be happy to get anybody a bottle if they want it. I don't know the price, but here's a pic....
i've used 3m automotive headliner glue for years in my dirt bike and BMX days.
I always wire wrapped them too though... But now, i do that because it looks rad :)
Do the hot water business, a squirt of hair spray, jam it on as far as possible, then stick the compressed air nozzle to the outboard side, a quick blast and it should pop on. Theoreticallyspeaking.....
NE
Thank you for this thread. I managed to get mine on using window cleaner, something I learned when removing tyres.
1 - 12 of 12 Posts
