Adjusting the valves on my CL450 seems pretty easy compared to this. YIKES! I removed about 75 LBS of plastic and frame braces to get to the valve cover.
Finally after about 2 hours I can see the valve cover!
Not too bad after this but I need to replace 13 of the 16 shims so both cams have to come out.
I can swap some shims around so I only need to buy 8 new ones. The shims are $10 each so it's still expensive, but better than paying the 7 hours labor the dealer wanted.
