Re: ‘74 CB360
I think I know the cam needs to be turned such that the lobes clear through the notches cut on the gear opening, since that’s what I did to remove it for a ring replacement. But no matter how I fiddle with it now to install - no go…The slippers are out and the chain adjuster is backed off to the max. There just doesn’t seem to be sufficient chain slack for the lobes to clear. I’ve searched YouTube and this forum - nothing found.
Any tip suggestions?
