Was messing around with the multimeter today and I’m concerned that my solenoid isn’t working. The battery is live. The red wire to the starter has current. The red and white wire to the regulator/rectifier has current. But the black and red/yellow wires (see photo) aren’t getting any current. Am I missing something here? Checked my fuses and they are good too.
They need to be plugged into the harness, lol Spino if you need help shoot me a "Conversation" I am usually around close enough to mine that we can compare. For testing, black goes to ground yellow/red goes to hot. Should click and make the starter turn.
Lol I haven’t gotten to that chapter of the Clymer’s manual yet. I had em unplugged to go step by step checking the wiring. I was gonna adjust the timing but I found there wasn’t any voltage coming out of the coils.
Trash the Clymer or use it as a secondary reference, but USE the Factory Service Manual for your guide.....
Someone will send you a link to the FSM in PDF form if you ask......
As for Voltage through the coils, Key ON, Kill set to RUN, points and condenser wires unplugged........
You may phone........
Yes, as Steve said above, use the Clymer as backup or as a beer coaster... here's a link to the FSM
