I was always under the impression that the CB/CM/CMX400/450 all had a 180 degree crank and fire eah successively then two rotations, but according to this site, it says it's 360? That's incorrect info isn't it?
360* is correct. You get 1 combustion per revolution.
So if that's the case, could one not make a custom manifold and use a larger single carb? I know I should be less lazy and search, but I wonder if anyone here has tried it?
