My friend told me that he thinks my high RPM cutting out issue on my CB350 above 7k rpm is due to the little inline fuel filters I'm using on each fuel line to the carbs.
I'm using these little ones
He said the flow from the petcock on these things is so poor that you'll starve out the float bowls if you don't have a direct line to the carbs.
My petcock won't shut off even with a new whizzer valve gasket installed, so I have two of these also inline:
This way I can shut off fuel for good, but again he's saying that I have too much stuff between the fuel tank and the carbs to allow the fuel bowls to remain full at wide open throttle.
Does this make sense? Is there a way to check for that? I was looking down at my fuel filters while the bike was cutting out and they had gas in them.
I'm wondering if there's some sort of other mechanical issue I haven't addressed yet.. cam chain stretch or the advance weights being out of spec and letting it advance too far or not enough?
