1. The rear indicators work fine until the front pair are connected.
2. The front indicators will not work without the rear pair connected, at which point the relay buzzes like mad.
3. If you run a jumper from the front indicators down to the rear and connect them instead of the rear pair, the front indicators work fine. But if you try to jump the front indicators off the rear then its back to point 1.
Can someone please connect the dots for me? At which point should I try to locate my fault?
