First I have to commend you for attempting to construct something you want but cannot find. Those two grey cylinders are indeed diodes. The stripe is the negative side. An interesting read on wikipedia explains some of the functions of diodes, to limit current to one direction only and to provide a voltage reference.
Here the diodes likely isolate the brake circuit from the running light circuit, so that the brake lights do not backfeed the running lights elsewhere. Without those diodes, when you engage the brakes all the other running lights would turn on too.
Measured resistance of the diodes would only be accurate with them removed from the circuit, not attached to the LED load. Note that multiple LEDs will draw more power and produce more heat than single LED, and might not be any brighter than incandescent. If you find a lux meter you can determine brightness of a typical 1157 versus your LED version. Some cheap LEDs are actually not brighter than incandescent.
My question to you is: why construct an 1157 bulb when reliable bulbs exist at low cost that also meet DOT requirements for brightness? See the Sylvania 1157 for $13 each that meets DOT specs and draw only 2 watts. Some regions require vehicle inspections and homemade lighting could be a problem.
