I'm playing the "Which Part is Bent?" game again...forks or triple tree on a CB450sc
Hello all,
A while back I had some issues with a bent frame up near the head tube of my 83 nighthawk 450. 8 months and almost $600 later that problem is solved. The guy did an awesome job at straightening and powder coating my frame, and yes I know I've probably paid him at least half of what the thing is worth to fix it. Yet I've run into another snag in the front end: it still doesn't line up right...now that the frame is straight it's better, but something is still bent and I'm leaning towards the triple tree/steering column. Here's why. When I slide the right fork through the right side of the tree, it binds quite a bit once the top of the fork protrudes through the upper portion of the tree. However, the left side is smooth as butter all the way through. I thought, maybe a bent fork? In theory (at least what makes sense to me), if a fork was bent, by switching the forks from right to left I should get the same bind from the right fork in the left side of the triple tree, and the same smoothness from the left fork on the right side, if the triple tree was not bent, right? Wrong. When I switched the forks, the left fork bound up at the top of the right side and the right fork was smooth through the left side. From a side view, the right side is raked in a few degrees more than the left. They should be even right? And it doesn't matter which fork is where either, the right still looks pushed in. Has anyone else experienced this? Fork problem or triple tree problem? Is there an easy way to repair this or do I just need to throw a few more fifties into the fire?
Thanks!
Hello all,
Thanks!
