Got my valves from the shop and they aren't leaking. Great! Now I need to get the torsion bars sorted.
Here are the torques I have.
LE: 48 in lbs
LI: 58 in lbs
RE: 80 in lbs
RI: 52 in lbs
I was able to shuffle with another set to get the one good one but I'll have to do something with the rest.
I was thinking of getting someone to weld up the lifters and then grind them back to be slightly thicker. Sound like a good idea? I also need to get my valve stems ground down a bit because when I installed the cam to check tappet clearance I was able to open the valve with the follower adjustment. Lobe set 180 from the follower. Does anyone have any experience measuring this?
LE: 48 in lbs
LI: 58 in lbs
RE: 80 in lbs
RI: 52 in lbs
