1 - 20 of 30 Posts
:evil:I'm looking for tires for my 1978 cb400a 18" rear 19" front, the problem is finding something like the original tread, I would appreciate any help.
Thanks
I'm looking for a tread like this front and rear irc-gs-11-motorcycle-tire.jpg
Thanks for the info, now to find a good distributor.
Hope your tires turn out to please you, yep, I hate buying tires also.
I have always ordered tires on line and mounted them myself.
The problem I have is finding a tire I like and getting the correct sizes,
CB400T II. I am looking at Dunlop K70s, tube type tires. They seem to be
available in the right sizes and fairly economical.
I with you on tire buying. I'd really like something like the Kenda761 front and rear, but with both 18in rims (cl360) selections are limited. Gets exhausting after while, gonna end up in a compromise anyway.
I have a 1979 cm400 and a 1981 cm 400 same problem. 16" rear 18" front
I bought OEM-style Dunlop K70s for my DOHC CL450, they're knock-offs I'm sure but look exactly the same - old-school sizes 4.00x18 rear, 3.25x19 front
Hey Tom where did buy your tires?
I put cheap Shinko radials on mine. They don't look "vintage" but they get the bike down the road. Now if I could only get the **** carbs dialed in...
EDIT" 1980 T2 with 19" and 18" wheels. I think they're 100/90/19 and 110/80/18 iirc. I'd have to go check.
I'll recommend the IRC GS-11 also - I have them on my 1979 CM400A - good handling, pretty cheap and a retro looking tread pattern. I will be buying them again.
Well I broke down and ordered the IRC GS-11 tires they look like the best match, now on to the cm bikes they use a 4.60-16 rear and a 3.50-18 front.
Discussion Starter · #16 ·
That looks a lot like a Dunlop K-70. I will put K-70s on my CB400T if I ever get it to run correctly.
Not sure about the sizes, maybe a no go on size. K-70s are tube type tires if that matters.
Discussion Starter · #19 ·
The problem is the 4.60x16" rear wheel that's on the CM bikes,I have looked everywhere on the web and haven't found them and I know they made them, I have a fine dry rotted one on one of my bikes.
1 - 20 of 30 Posts
