Yep, read AL's "Making progress" thread I have just replied to. I suspect you two may be similar and get on well.
Flushing out all that SLUDGE, Black death...
This applies to air cooled bettles also...
Half inch thick, no real supprised as the oil is very old and may never have been changed, ever !
Do you have access to compressed air and a liquid spray Lance ?
A Lance with a liquid pick up tube is better than the Lance with a screw on liquid container, but both are better than a squeeze bottle.
I am UK based so trade names are different.
Good solvents are either extremely flammable, especially in mist spray form, or highly damaging to your health, carbon tetrachloride chloride, add water, ww1 poison gas !!!!!!
So, with your chosen "safe" solvent, well away from property, face mask on, flush down from engine top via those 4 valve cover holes collecting the liquid that rains down.
Low pressure spray for low parts of engine to avoid splatter.
Clutch side access holes, oil ways and any oil troughs. Genny side will have sump access holes.
Then, Lance up and about oil pump hole.
The more crap you get out now the better, so do a really good job.
When all crap flushed out, allow liquid to drip for a few hours, tipping bike side to side ( and front to back ) to get all that flushing liquid out. Make sure any oil troughs are flushed out of crap and flushing liquid.
When you are satisfied all crap and all flushing liquid is out of the engine, fill your squirty oil can with engine oil.
Prime all oilway to make sure they are all clear, particularly to the cylinder head and crankshaft areas.
Prime until new oil is seen ooooozing from valve/camshaft areas, and crank.
Allow to stop dripping.
Repeat priming process.
I assume you have got the 4 alloy valve covers off ok ?
If not say so.
You are now ready for reassembly.
When assembled and oil added, spark plugs out, ign off, turn engine over on Kickstarter for 100 turns.
Plugs in, start engine, check for good continuously oil flow to cam area via an open valve cover hole, or two.
Some will say all this is over the top, I say best practise, it's your bike not Thiers. It will bill your bills not Thiers....
valve cover or three.
Dd23🤓open
