Any tips on how to remove the rubber boots on the front forks without totally destroying them in the process?
Remove the wheel and fender, then remove the forks individually from the "triple-trees" .....
Would be easier to describe specific sequence if we knew specific bike.....
OR, Phone me..... 540-525-5199
1973 CL 350. Fork tube is removed from triple tree. Just not sure how to separate from lower fork tube without totally buggering it up. Do I simply pry off?
Hot water to soften...I soak a small towel and wrap it around.... Gently pry up (it sits/locks into a pocket groove in the slider...)
