There are several things you will have to decide/determine before fabricating (or mounting) rear-sets. Number one on the list is " Will you have (or can you make) the clearance necessary to have them function well, comfortably, and foremost, SAFELY?".....
This usually entails relatively complete assembly except for the pegs and pedals (with at least the engine, exhaust, seat, and rear wheel mocked into riding position) , and some careful measurements and thought.
First, sit on the bike and locate where you want the pegs to be.....Simply moving them back to the "buddy-peg" position is common, but may not give enough height to locate the brake pedal in a comfortable position for your foot/ankle angle......Too high and your knees and hips will cramp.....Too low defeats their purpose, and they'll drag in turns (NOT GOOD!) Remember, your toes will now be positioned pointed down at the roadway when you are in the "tuck"........ Get seated comfortably, and have a friend mark where the front of your heel is placed (a bit of masking tape helps here) This is where the peg SHOULD be...... Are there existing mount points nearby? (How will you mount the components?)... Will the peg, pedal, linkages, and bracket (if necessary) clear the kicker?....Pipe? ...... Chain? Will the linkages bind on the swingarm anywhere in its arc?......
If the answers are everything will clear, you can proceed...If not, you'll have to re-engineer the linkage paths, or alter the position slightly (if it would still be comfortable.)
Once you have determined all this, it's time to fabricate.....
Now that you have the basic idea, I'll show how I proceed on the 90, with more detailed explainations and pics..... Stay tuned!....
Steve
