I went for my first ride (longer than around the block) this evening for about 40 miles on my 1968 Honda CL350. At the end of 20 miles the electric starter would not work but I still had a strong headlight (not running headlight while riding unless it's dark). When I got home (night ride with headlight on) after the second 20 miles it would not start with the electric starter again. I kick started it and, while running, checked the battery voltage. At idle it was about 12.05v (11.75v with key off) and would jump to only 12.25v when the engine was revved to over 2000rpm. It had a new battery about 2 months ago with very little riding.
I checked the rectifier in both directions with a digital meter and got about 37k ohm in one direction and about 3.5k ohm in the other so I'm assuming the rectifier is good (it's the original part).
My next thought is that I have a bad regulator (3 wires, blk/grn/yellow). Can anyone recommend a procedure to verify the regulator is functioning properly?
I will be ordering a rectifier since it makes sense as a preventative measure but I don't want to shell out $90 for a regulator w/o verifying it's not functioning properly.
Any help would be appreciated.
