Does anyone have a good technique for adjust the twin leading shoe front brakes like those found on early CB's and CL's?
Prior to today the lever pressure on the front brake felt hard but the brakes feel weak. I can grab the front lever with all my force and it just sort of slows down. Even when holding the front brake had at a stop I can roll the bike slightly.
Today, I re-aligned the punch marks on both pivot pins to the brake arms. This seems to have helped the braking A LITTLE but it still doesn't feel very strong. At a stop now, I can hold it with the brakes and can not roll it at all. However, the brake lever feels a little soft. It is adjusted so that it engages after about 1/8" but the lever doesn't feel nearly as hard as before.
The manual does not talk about how to ensure that both shoes are engaging at the same time which I think might be my problem.
