i just put a new clutch cable on
1971 honda cl450
if i put the bike on the center stand, pull the clutch in and put it in gear... the wheel will spin.
there is not any freeplay, and the snapback feels great.
i'm aware of where to adjust, but how should i adjust to eliminate this problem?
thanks!
As above, when you pull the clutch lever you should be able to spin the rear wheel. You also should have a bit of freeplay in the clutch lever.
Do you have the factory service manual?
