Morning all, I picked up a basket case 1976 CB500T as a project and I’m wondering if it’s too far gone.
I pulled the oil filter just to see how much goo had accumulated over the decades, and found a serious amount of glitter in there. Absolutely caked in metal flakes. I tested it and it was magnetic. So I pulled the top end apart and found it had eaten The upper timing chain guide bearing. The metal seems to have gone through every passage way and acted as a sort of grit to wear everything else down.
The pistons and cylinders look great, and the lower end seems to be tight. Of course it’s all going to come apart anyway.
My question is, in the opinion of the experienced members among us. Do you think it can be saved? One of the cam bearings is significantly worn, and I’m not sure it’s even possible to locate those parts anymore. The rockers and the Cams appear to be worn as well. I’m thinking this is one of the sources of the iron metal flakes.
Thanks all
Thanks all
