1 - 2 of 2 Posts
So, like many of you, I had an oil drain plug that would not come out. After rounding off the corners of the bolt with a standard wrench, I rounded it off even more with a pipe wrench. I tried using penetrating oil and heat but I could not get a good grip on it. I finally got out the Dremel and a cut-off wheel and went to making a new bolt pattern:
[attachment=3:20wie962]DSC_0001.jpg[/attachment:20wie962]
[attachment=2:20wie962]DSC_0003.jpg[/attachment:20wie962]
Then I put a big ol' Cresent wrench on it and tapped it a few times with the rubber mallet:
[attachment=1:20wie962]DSC_0004.jpg[/attachment:20wie962]
and viola!
[attachment=0:20wie962]DSC_0005.jpg[/attachment:20wie962]
Hope this helps someone out.
Bjorn
1 - 2 of 2 Posts
