took the rear wheel off my 71 cb175, what holds the sprocket in place? I see the 4 pegs that go into the rubber grommets, anything else hold it on? or is it suppose to float?
This is my stock cb160 rear wheel, it doesn't have that weird unlabelled ring in the fiche though. The nuts on the damper studs hold it on, then the circlip goes over and pops into the slot. If you're trying to put that sketchy way too many toothed sprocket back on it's not gonna work, order a stock one and it'll probably pop right on
thanks, found a sprocket and hub assembly on ebay, I will just use the parts I need.
