man, so for the life of me i can not get these F'n shocks apart! never done it, can not find anytihng on it... anyone haev any tips/tricks? i have a spring compressor... and here are the shocks (radian shocks and virago 250 shocks) i need to powder the shocks on them, but can not get em apart... here is what i got...
i just do not know how to do it or where to hook what.. i have done the springs many times, just always get them sent to me taken apart!
IF they're like Honda shocks, then there are a couple of "keepers" at the top of the spring, similar to valve spring keepers.
If you compress the spring a bit, you should be able to remove the keepers (on Hondas at least).
Its very doubtful you will be able to use automotive shock spring compressor, its just too big.
The ones I've seen use a circular hole which fits top spring collar but leaves enough room to remove colletts, couple of threaded rods and a cross piece through the lower mount. ( its more difficult to describe than I thought it would be)
These look pretty simple to make
http://www.alssnowmobile.com/PRODUCT.AS ... eptid=1001
http://www.bikebandit.com/product/1946
http://www.jcwhitney.com/PROGRESSIVE-SU ... _10111.jcw
PJ
Personally, I just use a couple of flat-nose wood working clamps.
Wit a bit of care, it works fine.
It's tough to get anything into the "tight" end of the progessive winds.
I took my cb350 shocks apart a little while ago and all i used was some elbow grease and some big zip ties. I just ran them through the springs in three spots closed them up and then took turns compressing the shock as I tightened the zip tie. As I got it down enough I gave it one big push and pulled the locking caps out.
I put them back together the same way. I don't have a vise but if I did you could do it in like 2 minutes.
