1 - 10 of 10 Posts
Bolt the case on dry first, to see if the kickstarter binds, it may need the thickness of that gasket for correct end-play.
CB77, 1966
You could learn how to make a gasket ?
I agree. Using HondaBond or any other 'gasket goo' will never be satisfactory. You can buy gasket paper and cut your own. I would try a car parts supplier, especially one of those that supplies parts to car repair shops. Gasket paper comes in different thicknesses so take along a piece of your old one.
If you already have a gasket set Buy the Paper from an auto parts store TRACE It and cut it out.
As Yendor says, one sheet will cost a quid i know as i have just done that myself.
Start with two holes to locate the gasket in place, gently rub around the inner and outer rim of case then cut with scissors leaving 3/4 mm overhang.
Take gasket off the out case and relocate on the engine using the two location holes to make sure nothing touches anywhere.
CB77, 1966
Another method is to lightly paint the sealing surface with something that dries slowly, print the shape on the paper and clean the surface.
1 - 10 of 10 Posts
