If you static time your Twin, but notice the strobe isn’t showing proper advance, then the advancer is goofy.
Now, lots of stuff can go wrong with advancer units.
They can get dirty and stick - they can stick open, closed, in-between, or just be “sticky”......
And this usually happens when it’s been running and is very hot, too hot to mess with it, or even check it.
The springs can get worn out - that would cause the advancer to kick in too soon, at a lower rpm.
Some folks shorten the springs slightly, but there’s the danger of too much tension on the springs, which means the advancer would kick in too late, at a higher rpm, and might not advance fully at all.
I’ve seen folks manipulate the little tabs in this photo - usually they add a bit of shim inside it so the tab physically stops the advancer weights at a particular point.
[/quote]
This is better than the shop manual.
So if when doing the strobe timing and it won't fall in between the advance marks, instead of trying to manipulate the tabs or the springs is replacing the advancer unit or just the springs an option, are they available from honda?
A strobe light is on my 'tools to get list' now
