hi im new to this forum and i would appreciate any info on honda 175 slopers like gasket sets are 175 gaskets the same as cb160 gaskets also a source for gaskets and what parts are interchangeable on later 175s my bike is a 1968 uk model cd175a sloper i am living in Ireland thank you in advance
Some 160 and 175 sloper gaskets are the same, as are some sloper 175 and vertical 175 gaskets.....
The BEST way for you to verify what will and what won't work is to look up the part numbers....Same first eight digits, it should interchange (as supersessions are noted in the last three digits), ALL digits match, it's the identical part........
The same can usually be applied to other (hard) parts as well....My sloper 175 cases now carry a CB175 (vert) cylinder and a CD 175 (vert) head with a smattering of CB200 internals here and there.......but verifying oiling passages are appropriate and "match" the part to part junctures is critical....
