What are the differences between the SL350 engines and the CB350 engines, if any?
Discussion Starter · #2 ·
Will it work in a CB350 frame?
The early model SL is pretty much a CB/CL engine in a modded frame... the later ones had different heads and carbs (slide type PW24's instead of the 28mmCV's), and there were some gearing changes as well.... They all will fit in each other's frames but to use the later SL frame, you have to remove the starter motor....
Great thanks. Will be putting a sl350 motor into a cb350 frame
Other than the throttle cable, it's a bolt in......
hang on a minute.
Even though this is an old thread there are some differences between SL motors and CB motors
the SL350K1 and K2 HAD DIFFERENT LOWER MOTOR MOUNTS AND DIFFERENT COUNTERSHAFT OFFSETs
they can be MADE to work but they are not direct bolt ins...
