Hello My name is Mark I am trying to get a honda sl350 running It starts but it just sputters and pops the more throttle the worse it gets I rebuilt the carbs and adjusted the floats set the points and timing adjusted the valves and nothing changed seams like a timing issue because when its running I can move the timing way out and it gets better Is it posable to check if the timing chain has jumped a gear without taking the engine apart?
