So I started this project about 10 weeks ago. I have never fixed up a bike nor do I have my license. But decided what the hell. Thought that I'd finally start posting about it but it may take me a few posts to catch it all up. Picked up a Honda SL175 1972. Bike turned over but hadn't been started in 25 years or so. Someone somewhere along the way had taken off the exhaust system, and it was missing the left side air cover and the speedo case and mirrors but other than that was in pretty good nick. Had only done about 4500 miles!
So I started by replacing the spark plugs and changing the oil. Put in a new battery. Cleaned out the fuel tank, and replaced the fuel lines. I put on some inline filters but they were terrible! Didn't let the fuel through. Try flipping them around as I thought maybe I had put them the wrong way around but no. Should have spent more money to get better ones. I will eventually put some on but this is a job for later on. The drain plug was really stuck on and I had to extend the wrench to get enough torque by attaching a 1.5m metal pole onto the end.
It was at this point that someone pointed out to me that the front fender was on backwards. Weird. Anyway swapped it around.
I tried taking the right air cover off and it started cracking so that put me off. I ended up using some soft rubber on the end of a stick to push it from the other side. I took off the air filter body which had some perished foam still on it. I put some fuel in the tank and fired it up. Wouldn't really idle but I figured after 25 years that wasn't too bad.
I ordered some air filters from UniFilter and currently have put the left side on. Still have to clean the right one.
I found a guy 30 minutes away who had two sets of exhaust pipes. They were in okay condition, some better than others. There were a few holes in the one that I wanted to use for the right side so I took it to a mate who welded on a new piece of steel. It's a bit of an eyesore but it's functional. Figure that I can replace it down the line or cover the pipe if need be.
Then came the search for a muffler. My neighbours were not enjoying me firing it up nor was my family as it is under the awning of the house so the noise reverberates a bit. All the ones I saw online were pretty rusted out and expensive, especially the postage as they all seemed to be in the US and I'm in Australia. I pondered it for a bit and decided that I'd buy a couple of megaphone mufflers and would rig it onto the bike somehow. Anyway they arrived in the post and I sat on them for a couple of days. Meanwhile on Facebook a guy was advertising wrecked Honda parts. He didn't mention SL175's but I thought I'd messaged him anyway thinking that I might get lucky with some parts. Amazingly he said that he had a muffler for an SL175! He also said that he had an air cover. No heat guard but hey I'm not going to complain.
He was only a 20 minute drive away too which seemed way too fortunate. Yesterday I went and collected them both. The muffler is in really good condition. The air cover seems to have been painted at some point to be black but underneath it seems to be blue. I'm going to have to figure out how I can clean it up. I couldn't believe that it was the cover that I was actually missing! What are the odds? 50/50 I guess but anyway.
So that pretty much is where I'm up to. I've driven it forward about 1 metre to see if it works. Seemed fine. There are still a few things to do. Get a heat guard, put on some inline filters, sort out the air covers, there are a couple of small cracks on the frame that'll need to be welded, attach the muffler, clean up the bike... The metal could use a lot of elbow grease. I've started this process but it is taking ages...
