it start and idles and runs ok when cold but starts stalling worse and worse after warm up when putting it in 1st gear.Carb have been cleaned and adjusted , plugs look ok .I have checked gas cap vent. I noticed it idles a bit high as idle adjust is screwed out max and has no effect anymore. Any ideas. Something else besides carbs?
Idle adjuster screwed out and it's still idling high? That says the linkage is binding or the throttle cables are sticking. I'd start by going thru the entire tune process including sync of the carbs.
Dont know the history of the bike nor have I seen it but if the throttle and choke cables run around the outside of the upper motor mount they will bind up. I have found it best to run them in between the upper motor mounts.
Just a thought.
Bill
