What exactly is happening or not happening? Is it the lever you can't move or the clutch not engaging? Did you do something to the bike?
I'll PM you a FSM to start with.
Just saw it's Hondamatic! Do know much about them, but hopefully the FSM will help or somebody with knowledge will get back to you.
We'll need to know more about what's going on with your bike to help diagnose any problems......
The 400a tranny is pretty simple. You will need a FSM. If the shift lever is locked and wont move at all you might check the shift drum. Bad news is you will have to drain the oil and pull the torque converter and primary gears to do this. If all is ok you will have to split the cases to check the tranny. 1st gear is on one side and 2nd is on the other all the shift drum does is move the shift plate from one side to the other. I hope someone can come up with something better.
Bill
