Hello,
I bought a Honda CJ360T brand new in 1976. It last ran in 1984. This past winter, I rescued it from my father's garage, cleaned it up, put some new tires on, installed a new battery, points, fork seals, etc. It has 33,800 miles on it and looks terrific. I also rebuilt the Keihin CV carbs. It started right up! Although it runs and I can ride it, I'm having an issue that I can't seem to solve. If it's idling and I increase the throttle, the revs shoot up they way they should, but instead of going back down to 1,200 RPM, the engine races at about 3,000 RPM. I've tried adjusting the air valves on the carbs and adjusting the idle speed screw, but nothing helps. Eventually, the RPMs go down and it will idle, but it sometimes stalls or makes "popping" sounds from the muffler. The "popping" sounds seems to make the left carb move, too. Other than that, it pulls strong and rides pretty well for an old bike. It even starts on the first kick! But this idle issue is not good. Do you have any ideas about this? I'd appreciate ANY input very much because this is beyond my level of expertise. Thank you in advance.
Tim
Syracuse, NY
Tim
Syracuse, NY
