Honda CD200 Roadmaster Rebuild/Restore
Hi All,
My name is Johan and I'm from South Africa. I've been riding motorcycles for almost 5 years now, but was recently intrigued by older motorcycles and the prospect of getting one that needs a little TLC and that I could possibly then restore.
After going through a couple of makes I settled on a Honda CD200 Roadmaster, a model I believe was exclusive to South Africa and Pakistan.
The model I got was, according to the previous owner, the last CD200 sold in SA, a blue 2005 model with 45000km on the clock (6v with CDI ignition).
The bike needed a bit of attention from the start, bot looked good overall.
I struggled to get it started initially. It turned out that the plugs were 'fouled', so I replaced it and it went well. It stood for a day or so and when I wanted to start it again it refused. After checking the plugs I noticed that they were fouled again, but not as much as as the older set. I checked and did a couple of other corrections while I was at it.
I cleaned the carb and changed the petrol filter. Unfortunately none of this made a difference and it would not start. I then removed the air filter and it looked dry. To my surprise I tried to start the bike without the air filter and it did, however it ran with a pop pop and splutter. I also noticed some white smoke coming from the right exhaust (if standing behind the bike).
I'm in the process of cleaning the air filter and putting it back on, but I'm wondering if that would solve the issue, somehow I doubt it.
I'm at a crossroads now of whether I should start thinking of taking it from top to bottom and 'restore' it, thus covering all possible problems.
So depending on what the air filter does and your comments and suggestions I might be posting some progress logs quite soon.
Regards,
Johan
Hi All,
Regards,
Johan
