21 - 27 of 27 Posts
Discussion Starter · #21 ·
I got the angles worked out and the rest of the exhaust tacked into place. I'm happy with the way things turned out. The bracket on the right side interferes with the current brake linkage setup but I had planned to switch to clevis pins anyways so once that's done I'll have plenty of clearance there. I also purchased a metal bender from Eastwood. The vise brake is fine for thin metal but the thicker stuff, even 1/8" flat bar really strains the vice and I don't want to to ruin another one.
Discussion Starter · #22 ·
Weather's getting colder which means I can finally get back into the garage. The exhaust is all welded up and sounds great. I really like these Emgo mufflers. I have the same type installed on my CB77. Not as quiet as stock but not so loud that you can't ride with them for extended periods.
Mike what did you do with the 2 into one exhaust system that was on this bike? been looking for one for some time now. I PMed you. Thanks
21 - 27 of 27 Posts
