Hi, I'm having problems with my honda cb250 G5 1974
It won't select first gear. I have removed the clutch to gain access to the selector rod and drum. Here is a video of what is actually happening. Ive been through the gearbox itself and nothing it sticking out to me as being wrong or worn
If I turn the rear wheel as I'm spinning the drum it tries to select the first gear but doesn't quite slot correctly into the drum first time. This is causing a grinding noise as I pull away until it slots into gear
The rest of the gearbox selects fine, its just that first gear
Any help on this would be greatly appreciated!
