I've got a manual but I'm still confused as to where to measure from. It says to measure from the bottom of body. The photo in the manual shows to measure on the outside from where the arm fits into the side to the bottom of the float. Can anyone shed some light on this for me? Thanks!
Measure from the gasket surface of the body.... If gasket stuck, subtract about 1/2 mm from given setting......
Discussion Starter #6
Thanks Steve! That's where I thought you measured from but that's not what's shown in the illustration in the manual I'm looking at.
Discussion Starter #7
Has anyone ever checked the levels in the bowl with the clear tube method? I've set both floats to the 21mm height the manual says and am getting two different levels in the carbs. Matter of fact they are a 1/4" different.
