1 - 1 of 1 Posts
Shipping something flat like the studs or seals, ~$3 USPS in an envelope, or $8 USPS Small flat rate, unless too big to fit then $12 USPS Medium flat rate.
Originally from/for a 1973 CL175
1) Newish Motion Pro throttle cable Made for OEM carbs : Make offer
2) Transmission counter gear sets, will separate:
A) Drive shaft gear set 100% complete including set ring & good seal ready to drop in.
B) 1st gear shaft gear seat (seen in pieces), complete, yet 1st gear is slightly chipped (like always as is the kickstart countergear) yet doesn't need to be replaced, yet should if only kick start. The slide on bearing is shot, if yours is good you can slide on and drop this entire assembly in.
3) New cylinder head gasket set with both green o-rings: Make Offer
4) NOS exhaust studs x3: Make Offer
5) Swing arm seal kit: Make Offer
310252
310253
1 - 1 of 1 Posts
