Hello lovely people,
I am just rebuilding my cb360 and i found Ricks Motorsport Electrics High Output Charging System Kit i bought while ago. i remember that was not working, but i would like to give it one more chance...
Is there any way how to check or test stator or regulator/rectifier? off the bike?
or may there be any other issue in my electric system blocking charging?
If anyone can help me it will be great :)
Thank you all
Yes, some of that CAN be tested off the bike.... Phone me in about an hour or two with the bits and a multimeter at hand....540-525-5199...Steve
Hi 66Sprint,
Im sorry i missed your message. im in uk and its quite late so i was not able to ta replay. I chceck youtube and there were few videos how to measure stator with multimeter.
I took few pics. everything was looking fine expect ?ohm? ... usually they (youtube) had numbers around 0.4 but mine was different (maybe i did something wrong, Im not familiar with multimeter :D)
I have cheap multimeter and maybe i was not able to get right numbers. if by any chance you can have a look at pics and let me know what do you think?
Thank you very much
Your stator appears to be fine .......
Please post a pic of the Reg/Rect (showing all the wires) so I can tell you what probe color and to which wire.......
I found video also about Reg/Rect ...
i did positive to negative and negative to positive while changing both yellow connectors....
I did all possible combinations. here are few pics...
do you think its fine?
You have a single phase system..... NOT three phase.....
Yeah I know it’s not the same, but the way how to check is not the same? I thought instead of 3 connectors i checked just 2...or is it totally different way how to check it?
I will try to find other video
