1. my manual asks me to aline the alternator rotor to the timing mark to the housing (LT)
2. then im suppose to position my timing marks on my cam chain sprocket parallel to the surface of the cylinder head.
3. when i do so i loose my mark on the alternator w/ the housing (LT)
Is that suppose to happen or how do i go about keeping my timing marks aligned????
Thanks
Re: honda cb 360 cam chain sproket and alternator rotor timi
They MUST be simultaneously aligned.... Try "skipping" the chain on the camshaft sprocket so that occurs.....
So i got that taken care of. How important is it to adjust the cam chain? should i bother or not?
Absolutely do it.
i have no experience doing it. i do own the manual for refrence. Any special tips and should i add oil in the engine?
You don't need to add oil just to adjust the cam chain, it's a spring/mechanical linkage. Just follow the manual's instructions and you'll be fine.
