How to adjust Throttle cables, synchronize carburetors, idle mixture and idle speed on 350 and 450 honda twins. DIY tutorial with step by step instructions to get your motorcycle running right. Solves hesitation, popping, backfiring and poor performance problems.
Where you get the dummy spark plug clip? Great video!!
Ok, the first thing in the video I noticed was when he removed the gas tank. The fuel balance hose was routed over the frame, instead of under. Is this ok to do?
I'm hoping it is, because it's always a pain to remove my gas tank on my CB350.
Only if you don't mind running out of fuel or sloshing your tank around trying to get it to the petcock side.
It's one of many shortcut things that guy does. His videos are almost as bad as Common Motor's stuff
