So I finally got here.
going to start putting some info on the 378cc conversion I'm doing on 1974 CB360.
I'm building two bikes which will be similar but not the same ( one is getting all the frame brackets removed plus modifications to clutch cover to run external cooler and filter)
They are both running Suzuki GS850 pistons which seem to be a direct replacement (and 3mm oversize :lol: )
Quite a bit of stuff got lost when hard drive died (still trying disc recovery software to see what I can ge back-doesn't look good so far)
I put quite a few pictures on photobucket and some are still on camera memory card.
may take a couple of weeks for me to find time to get everything on here
Last pic is modified clutch hub, extra oil flow helps to cool plates.
Put both dyno runs up, first is with MAC pipes, second with with new exhaust system I made.
Its running really, really rich (10:1 fuel air ratio) going to down jet and try to get another run sometime. I 'lost' almost 3hp from the open exhaust/original numbers
somewhere new to bore people with my CB378 and XS650 Yamaha stuff.
link to the 378 I'm building
And the link to SOHC4 in case you missed it
http://forums.sohc4.net/index.php?topic=30210.0
:lol:
Will start posting when I have more time.
PJ
I've edited the 'me again' post, removed pictures and put link to this one, just in case anyone finds it in the future
http://s91.photobucket.com/albums/k315/ ... a%20CB360/
:lol:
PJ
