Cb350 with vm30 carbs. Fixed one problem - only to inherit another. Fixed the hanging idle - was the throttle cable. Now I can only start the bike with the choke open. If I close the choke, the rpms shoot up to 6k rpm. Don’t ever remember hearing the popping out of the exhaust before.
I adjust cam chain, adjust valve lash, and ignition timing. It may be the ignition timing. I noticed that the right point would occasionally light up orange at the contact point instead of lighting up the test light. I have new points on the way. Do you think that’s the problem?
