Great looking bike! What kind of help do you need?
hey Thank, this is the situation,
i did change the asbesto clutch disks but y do not find in the manual the torque specifications of the bolts of the clutch lifter plate. i appreciate your interest
Use the 6mm bolt standard value (6-9 lb ft or 0.8 - 1.2 kg m) since no special torque value is given in the manual
More important is tightening in a cross pattern, slowly working up to the torque spec
I saw this table before, but I did not think it would be applied to the clutch screws, consider that they had a special touch! hahaha, a thousand thousand thanks. I will tell you if I can make progress- !!
Welcome aboard. Lots of information in the SOHC section of the forum and what you don't find be sure to ask.
