It's a 73, I think. Pulled the carbs and cleaned them, I have an obviously stuck float as gas poured out of the overflow, so I guess I'll have to get back into that.
More worrisome at the moment is no power to anything, picked up a battery, seems mostly charged, but no lights, turn signals, starter, nothing. Totally open to suggestions.
Mostly I'd like to know if there is a way to bypass everything and just get the starter turning.
You can hit the starter with battery currently directly to see if it cranks...
But before anything ... even a kick start ... change the damn oil please... Dont kick up all that settled sludge.
Before electric starting... crank with the kick start and see that it turns freely ...
Then pull plugs and check for spark (hold against engine frame and kick over with a friend)...
I can help with wiring needs as it comes up.
Sent from my SM-G930V using Tapatalk
