I have removed folk assembly from the bike . Removed the 47mm cir-clip and also removed the Phillips head screw from end of the Bottom Case and the Lock Piece (which came out through the top pf the folk pipes). My model (K1) does not have the Allen head bolt. I am trying to replace the fork seals. I can not get the folk pipe out of the bottom case. What am I doing wrong? Thanks
If it's like my '69 350, once the large circlip is removed, you just pull the slider downward a few times against the stop and the seal will pop out, freeing the fork tube. There's nothing holding the tube in the slider but the seal and the circlip.
Thanks 83XLX Got it out . It was really stuck in there .Just need to use a lot more force.
