One thing that i have found over the years is that
some people adjust the brakes just by using the connecting rod only, all this achieves is that one shoe makes contact before the other giving reduced braking.
You need to adjust the connector between the two Brake Cam Levers (arms) so that both ends of each shoe contacts the brake drum at the same time.
To do this, loosen both the cable adjuster and the rod connecting the two brake cam levers. Tighten the cable adjuster. The one on the brake drum, not the one on the handlebar. When the brake starts to drag, keep turning the wheel and get a good " feel " of how much drag there is. Now tighten the rod going to the other brake cam lever till the drag " feels " about twice as much as before. Tighten the lock nut, then adjust the cable so that there is at least an 1/8" of play at the handlebar brake lever.
By adjusting the play you can make the brake lever engage the brake wherever you like. Like closer to the handlebar if you like. Just make sure there is enough free play in the cable so the brakes don't drag, and that the lever does not touch the handlebar when they are on full panic :shock:
How do you tell if they are dragging ? Feel the drum after a short ride. If it is really hot and you have not used the brakes much, they are dragging. If you are sure the brakes are not dragging and the drum is still hot, check your wheel bearings.
Edit:- Genuine Honda pads are made using 1960-70s technology
so before spending $ have a look for a relining service that uses modern friction material AND has a history of relining motorcycle drum brakes and get the friction material that suits your riding style, the cost should be similar or slightly more expensive.
Personal option :shock: You should never compromise on brakes and tires as these are the two greatest factors on a motorbike that will save your life
Edit number 2:- Another trick/mod you can do is shaving the leading edge of the shoes in 1/2" steps so that the shoes initially make contact in smaller increments giving you the ability to use the brake to softly slow you speed in a situation where you would normally not use the brake, I'll leave it their, let you think about, and wait for the responses
Edit number 3:-
