HELLO AGIAN
I KNOW THIS WILL SOUND RETARDED
BUT CAN SOMEONE TELL ME HOW TO GET AT THE FUEL TANK
TO REMOVE IT AND THE SEAT??[attachment=0:37q863o8]Picture 021.jpg[/attachment:37q863o8]
I'm not certain, but I'm thinking there are two levers (one on each side of the seat around where the passenger sits). Just need to push these two at the same time and it pops off.
Again, not 100% on this but worth a look. Once the seat is off you'll notice a bolt holding the tank (at the rear of the tank). Once you remove this, you can slide the tank back to remove it from the front rubber pucks.
Also, I moved this to the Tech Info section as you'll get more looks here.
THANX AGAIN PERRY
I'LL GO HAVE A LOOK
I AM CHARGING THE BATTERY TO SEE IF IT'S ANY GOOD
INFLATED THE TIRES (MAKES IT MUCH EASIER TO MOVE
BUT I NOTICED IT STILL HAD FUEL IN THE TANK
SO I WANT TO DRAIN IT AND LOOK AT THE FUEL LINES
THANX AGAIN JOHN
