So after asking the question earlier about upgrading my 70 CL to the newer style 73/74 forks I decided to keep her stock because of the extra cost/work. However yesterday I found the left lower fork case was cracked so I need to replace. Since that's the deal it now makes more sense to upgrade to the later forks. However I'm having a hard time sourcing parts and I'll soon be at a stop until this is sorted. I did do research. There is a set of 74 front forks on eBay but I'm unsure if they just drop in or do I need triple parts etc. Also lowers I can clean up but not sure if or how you can clean up crappier tubes...
IF I were to keep it stock the lowers I've found on eBay are in rough condition - anyone know if other honda lowers from other bikes work? The CB450 lowers are not the same Honda part #...
Any help to keep me going is greatly appreciated!
Thanks
DW
Thanks
DW
