Thanks for looking!
I am in need of a front caliper or internal actuator. For a 75 CB200T.
Or if someone knows f there is a hyd. conversion that can be easily done........
Thanks for all your help !
Badger 5 said:
I would love to find a way to convert the front brake to a better system.
Mine works fine, just have to keep it clean.
Stops better than a drum brake........
Thanks for the lead ....but that is just the caliper housing. I need the part inside that the cable connects to.
Has anyone looked at the hyd caliper on a 350?it appears to have a very very similar mount?
Thanks!
You could fabricate a mount and use a small hydraulic caliper such as are used on many mopeds (50cc scooters)..... I did a similar mod (although much more was involved) on my Daughter's Honda 90 using a CB200 wheel as the basis.... The calipers and masters are not too expensive, and would be relatively easy to mount to the 200 Honda forks....I probably have a spare set of components lying around.....You canPM or e-mail me if interested in discussing the mod further.... Steve
