1 - 2 of 2 Posts
It's almost impossible to rebuild an engine without stripping a thread. Here is how I fixed mine.
I use the Recoil kit.
[attachment=4:2jo7l4cu]SSA50722.JPG[/attachment:2jo7l4cu]
Here is the stripped thread.
[attachment=2:2jo7l4cu]SSA50709-small.jpg[/attachment:2jo7l4cu]
I masked off the the area. Don't want any metal flakes in the engine. The tape on the drill bit is to know how deep to drill.
[attachment=1:2jo7l4cu]SSA50718-small.JPG[/attachment:2jo7l4cu]
Then I use the tap in the kit.
[attachment=0:2jo7l4cu]SSA50720-small.JPG[/attachment:2jo7l4cu]
Then I put the thread coil on the tool.
[attachment=3:2jo7l4cu]SSA50725.JPG[/attachment:2jo7l4cu]
Discussion Starter · #2 ·
Re: Project CB450 K1/K5 - Black Bastard refurbishment
Then I screw in the new thread coil. It's important that the end of the thread coil is screwed about 1/2 to 1 turn into the thread to grip correctly. In critical applications I use a small amount of Loctite thread lock to be sure the coil stays in place.
[attachment=2:1vqbuec0]SSA50727.JPG[/attachment:1vqbuec0]
Finally I hit the litte tab and pull it out with a long nosed plier.
[attachment=1:1vqbuec0]SSA50730.JPG[/attachment:1vqbuec0]
There you go. A new thread that is stronger than the old one.
[attachment=0:1vqbuec0]SSA50731.JPG[/attachment:1vqbuec0]
1 - 2 of 2 Posts
