Hello all, I just picked up a 1980 cb400t and I am having some electrical issues I was told about when I bought the old girl. My headlight works occasionally. I thought it was the fuse box there are only 3 fuses 15amp for the main and two 7 amp one for headlight one for tail. my box had some white almost looked like short on one side of the headlight fuse. I just got my new/used fuse box. put it in and the same mostly not working.
Now while I had the old box in I put some dielectric grease on the fuse and the light worked and then did not work. I am sure it's a connection. I am also having a little issue with the starter button. very touchy. I initally thought it was the starter so I put in a new/used one on and same issue. it works but needs light tough. I have not gotten in to the handlebar to see about the connection at the starter button if there is corrosion. I think the issues might be connected. I did take the headlight off and checked the connection from the starter side to the harness. there was a little corrosion so I cleaned connections and greased those.
I am not sure where to go to next. bike runs great blinkers work tail light works I know the bulb is not blown. I am use to yamaha's not honda's so a little at a loss.
any help is much appreciated
Mortikan
I believe the 400's use a dual switch for starting that opens (shuts off) the headlight circuit simultaneously with closing (turning on) the power to the solenoid....Since they "share" a common power feed wire, it is likely the problem is bad/dirty contacts within that switch.... Especially, as you say yours is "touchy"..... I'm basing this on a similar circumstance with another Honda I had.....It could also be any connection in/to that "shared" black wire......
I'd take apart the "spare" and clean it up for starters...(pun intended)..... :D Steve
well thanks for the fast reply. I was thinking that. I will do it tonight and see what happens
thanks again
Mortikan
dirty connections it was in the switch.
thanks again
I guess I am going to have to buy a manual now. I am thinking it might need some maint soon. it's got 27k on it.
Cheers Mortikan
What does this "dual switch" look like Steve? I'm having this same issue. Changed the fuse, and the headlight worked when I turned the bike on. Once I started it up, the light went out.
