Hello,
for the last few days i noticed a popping sound on my left exhaust, thought nthing of it really, then last night i put on the pod filters/cones and wnt for a ride with my friend, he noticed that when i was on the throttle white smoke came out, so i pulled over and notice that there is oil on the lower part of the cylinder, coming out from the head gasket.
so i guess i need to know these things:
1. is it safe to still drive like this?
2. are there any non-head removing ways to fix it?
3. should i move back to the paper filters?
thanks, for your help
-Dave
......and that means pulling the motor. First thing to do is a compression check and that will tell you a lot right there.
The other thing you'll need is a service manual. That will walk you though the sequence of pulling the head if you haven't done it before.
Good luck.
